Add Curtain Grid lines
Hi guys.
Does anyone know how to add Curtain Grid mullion to a Curtain wall using the in rhino?
For example, if I click on Curtain Grid in revit, I can add manually but I would like to select the curves in rhino and send them to revit using rhino inside revit.
@jameschadud currently there is no native RIR component to add curtain grid lines.
You can use the scripted component to add the curtain grid lines.
Here is a link to an older script Curtain Wall Grid - #72 by Japhy
Hi Japhy. Thanks for replying.
I have tried this script and Im its crashing revit 2026. Do you have an example how it actually works?
Thanks
Is there a crash report?
What is your about info?
I won’t have access to Revit till later today, maybe over the weekend. If your still having issues i’ll take a look then.
Hi Japhy.
Nevermind, I got it working now. Thank you.
But there is one doubt about the script. Once I send it to revit, Its unpinned right? Lets say if I need to modify it, I have to delete it manually in revit and re send it again?
Thanks
@Japhy
Also, is there a way to add or remove one segment only?
Yes it doesn’t have the element tracking you have to delete and generate the grids again.
