Can hops export data tree (or 'list of lists')?
Hello everyone,
I need export points in different layers (say, 5 layers, and each layer has 10 points) from Hops.
I created points using rhino3d.Points3d, then append them of each layer in layer list layer[…], then the layer list is appended in the final list ptall[…].
When I try to export using hs.HopsPoint, it shows the error
“1. Solution exception:Cannot deserialize the current JSON array (e.g. [1,2,3]) into type ‘Rhino.Geometry.Point3d’ because the type requires a JSON object (e.g. {“name”:“value”}) to deserialize correctly.
To fix this error either change the JSON to a JSON object (e.g. {“name”:“value”}) or change the deserialized type to an array or a type that implements a collection interface (e.g. ICollection, IList) like List that can be deserialized from a JSON array. JsonArrayAttribute can also be added to the type to force it to deserialize from a JSON array.
Path ‘’, line 1, position 1.”
Could anyone help me fix the issue? Thanks a lot in advance!!
