Hey there,
@AndyPayne Here’s the next step in the debugging of my huge grasshopper definition I want to run over compute. I hope you’re not getting too tired of me ![]()
I am not sure why, but I made some experiments with Hops and JSwan, and it seems that paths are getting somehow lost in the deserializing process.
I made a minimal example, demonstrating what is failing.
When using JSwan over Hops, to deserialize a JSON string, the data path I get as output is different from what it should be.
So what’s wrong in this demo is that the output of the JSwan over Hops should have the path {12;34;56}, and it is actually {12;3;5} (path of the first item in the data tree).
I made a custom python 3 script that does the deserialization just fine and the paths are working. So I will use that for now in my other concerned scripts where I faced the issue.
I thought it would still be a good thing if you guys could have a look at it, and eventually fix it.
I attached the minimal grasshopper definition for you to test, plus the 2 Hops definitions
local_geometries_tree_access.gh (5.6 KB)
local_geometries_tree_access_python.gh (7.8 KB)
minimal_demo_jswan_data_tree_over_hops.gh (18.5 KB)
