I’m looking to export data from Grasshopper via Hops, to use sklearn’s clustering functionality. This is all fairly straight forward for up to data structures up to 3 dimensions, as the HopsPoint can be used to handle the input.
However, I would like to be able to cluster data structure of 4 dimensions and above. The obvious way to do this would be to wrap the data in a datatree and convert it to a numpy array on the server-side, but there doesn’t look to be hops object that handles datatrees. Is there a solution? I’d like to keep the n-dimensions dynamic on the client side, so one input would be preferable.
