While setting the camera (using Rhino with Vray) for a small room in order to capture a wide angle ( walls, floor & roof), we are decreasing the lens length from 50mm to 20mm by to get a wider angle. When we do this, we find the view is stretching out, leading to the camera moving backwards rather than adjusting focal length. Is there a solution to this? Please advise on how we can capture the best view for interiors.
hi!
try dollyzoom
