I want to use GetObject.GetMultiple for the user to make a selection and be able to set an option, in this case an OptionToggle.
In the code below everything works as expected, except when toggleing the option after a selection has been made, the selection loses the yellow highlight. Its only a visual thing, the correct selection will be returned, but i would like the selection to stay highlighted even when changing an option, like it is the case with native Rhino commands.
Any ideas? Here is what i have so far:
using System;
using Rhino;
var activeDoc = Rhino.RhinoDoc.ActiveDoc;
bool stickyBool;
if(activeDoc.RuntimeData.ContainsKey("stickyBool"))
stickyBool = (bool)activeDoc.RuntimeData["stickyBool"];
else
activeDoc.RuntimeData.Add("stickyBool", true);
stickyBool = true;
var go = new Rhino.Input.Custom.GetObject();
go.SetCommandPrompt("Select Objects");
go.EnableClearObjectsOnEntry(false);
var stickyBoolOption = new Rhino.Input.Custom.OptionToggle(stickyBool, "False", "True");
go.AddOptionToggle("ScriptOptionToggle", ref stickyBoolOption);
for(;;)
var get_rc = go.GetMultiple(1,0);
if(go.CommandResult() != Rhino.Commands.Result.Success)
break;
else if (get_rc == Rhino.Input.GetResult.Option)
stickyBool = stickyBoolOption.CurrentValue;
activeDoc.RuntimeData["stickyBool"] = stickyBoolOption.CurrentValue;
continue;
break;
Console.WriteLine("Number of objects selected: " + go.ObjectCount.ToString());
By the way, i just tried to put this exact code into a command plugin and load the RHP, and it works as expected. In the script editor it doesn’t. Strange thing…
from __future__ import absolute_import, division, print_function, unicode_literals
#! python 2
import Rhino.Input as ri
def main():
go = ri.Custom.GetObject()
go.SetCommandPrompt("Select objects")
go.EnableClearObjectsOnEntry(False) # Default is True.
go.EnableUnselectObjectsOnExit(False) # Default is True.
go.DeselectAllBeforePostSelect = False # Default is True.
optToggle = ri.Custom.OptionToggle(False, 'No', 'Yes')
go.AddOptionToggle("ToggleMe", optToggle)
bFirstRun = True
while True:
res = go.GetMultiple(minimumNumber=1, maximumNumber=0)
if res == ri.GetResult.Cancel:
go.Dispose()
print("No objects were selected.")
return
if res == ri.GetResult.Object:
objrefs = go.Objects()
go.Dispose()
print("{} objects were selected.".format(len(objrefs)))
return
if bFirstRun:
go.EnablePreSelect(False, ignoreUnacceptablePreselectedObjects=True) # Default is True.
bFirstRun = False
if __name__ == '__main__': main()
is executed in the Script Editor, post-selected objects are also/still losing their highlighting when the option is selected, even though the objects remain in Custom.GetObject’s Objects. (The same occurs when the script is executed as Python 3.)
When the script is executed via _-ScriptEditor _Run, there is no printed output.
The objects both remain highlighted and in Custom.GetObject’s Objects with:
