Hide Highlight of geometry during operation
… to better see how geometry is scaling for instance.
Is there a way or shortcut to temporarily toggle highlights?
Thank you
I believe @Jarek had made a script for this
yes indeed, there different versions by Pascal and others floating around, but mine is here:
Here is a one-shot unhighligher that will work on preselected objects and then quit after the scaling operation (or whatever) is done:
import Rhino
import scriptcontext as sc
def Unhighlight():
    ids = rs.SelectedObjects()
    if not ids:
        return
    objs = [rs.coercerhinoobject(id) for id in ids]
    for obj in objs:
        obj.Highlight(False)
    sc.doc.Views.Redraw()
if __name__ == '__main__':
     Unhighlight()
Unhighlight.py (363 Bytes)
To use the Python script use RunPythonScript, or a macro:
_-RunPythonScript "Full path to py file inside double-quotes"
Thank you Pascal!
