I am using a custom input to get multiple curves with a toggle option. If I select a curve and then change the toggle, it deselects the original curve that was selected so if I select more curves only the newly selected curves are captured. How do I preserve what was selected prior to toggling the option so when other curves are selected they are all captured?
import Rhino
import Rhino.Geometry as rg
if __name__ == '__main__':
DrawSurfaces = True
cmd = Rhino.Input.Custom.GetObject()
cmd.SetCommandPrompt('Select the curves.')
cmd.GeometryFilter = Rhino.DocObjects.ObjectType.Curve
opDrawSurfaces = Rhino.Input.Custom.OptionToggle(DrawSurfaces, 'No', 'Yes')
cmd.AddOptionToggle('DrawSurfaces', opDrawSurfaces)
Done = False
while not Done:
result = cmd.GetMultiple(1, 0)
if result == Rhino.Input.GetResult.Option:
DrawSurfaces = opDrawSurfaces.CurrentValue
else: Done = True
print 'Draw Surfaces Option: ' + str(DrawSurfaces)
for obj in cmd.Objects():
print obj.ObjectId
import Rhino
import scriptcontext as sc
def test():
ids = None
go = Rhino.Input.Custom.GetObject()
go.EnablePreSelect(False, False)
go.GeometryFilter = Rhino.DocObjects.ObjectType.Curve
while True:
go.ClearCommandOptions()
#Objects selected so far
ids = [go.Object(i).ObjectId for i in range(go.ObjectCount)]
#highlight selected objects
if ids:
for id in ids:
obj = sc.doc.Objects.Find(id)
obj.Highlight(True)
sc.doc.Views.Redraw()
#set your default for the toggle
DrawSurfaces = False
#use this to keep track of what the setting was last
if "DRAW_SURFS" in sc.sticky:
DrawSurfaces = sc.sticky["DRAW_SURFS"]
go.SetCommandPrompt("Select curves.")
go.AddOptionToggle('DrawSurfaces', opDrawSurfaces)
#This is key, so as not to lose the selection:
go.EnableClearObjectsOnEntry(False)
rc = go.GetMultiple(1,0)
if go.CommandResult()!=Rhino.Commands.Result.Success:
return go.CommandResult()
if rc==Rhino.Input.GetResult.Object:
break
elif rc==Rhino.Input.GetResult.Option:
sc.sticky["DRAW_SURFS"] = DrawSurfaces
continue
print ("DrawSurfaces = " + str(DrawSurfaces))
if not ids: return
print (len(ids))
#Un-highlight
for id in ids:
obj.Highlight(False)
#Select if needed
for id in ids:
sc.doc.Objects.Select(id)
if __name__=="__main__":
test()
@pascal - This almost works 100%. Thanks for the code. The interesting thing is that prior to changing the DrawSurfaces toggle I can deselect any object that I have selected. Once I change the toggle I can no longer deselect any of the previously selected items. If I select additional items I can deselect those until I change the toggle again. Is this a bug where if you highlight an object via code that you can not deselect it?
I did a test run by highlighting two objects via the Highlight method and discovered that the objects cannot be deselected unless you either select the highlighted object again or select all objects and then deselect it. Not even ESC works to clear the object selection. Even if you select other objects and then press ESC it clears the newly selected objects but leaves the original highlighted (via code) objects selected. Sounds like it might be a bug/issue. I would think that highlighting via code would cause the object to act the exact same way compared to the user selecting the object. Please advise.
I thought I would replace Highlight(True) with Select(True, True). While this works when finding objects by their Guid, it would not work with the custom input.
