Thanks again, David!
I’ve changed my custom component attribute’s AppendToAttributeTree
like so:
public override void AppendToAttributeTree(List<IGH_Attributes> attributes)
List<IGH_Attributes> foo = new List<IGH_Attributes>();
base.AppendToAttributeTree(foo);
foo.Reverse();
attributes.AddRange(foo);
No I’m stuck with the annoying side-effects you mentioned
I’m able to handle mouse events on the component even if the end up on the parameters. For example, in my component attribute’s RespondToMouseDoubleClick
– which I would like to customize – I do
for (int i = 0; i < comp.Params.Input.Count; i++)
if (comp.Params.Input[i].Attributes.Bounds.Contains(e.CanvasLocation))
// TODO: Paint small menu on top of paramter...
However, I’m experiencing the problem that all other mouse events (up, down, move) do not get passed on to the underlying parameters. In RespondToMouseDown
I do:
// Pass the event to the parameter.
return GH_ObjectResponse.Ignore;
I thought that simply returning GH_ObjectResponse.Ignore
in the component attributes would cause the mouse event to be passed on to the next item in the attributes tree – which are the parameters.
I’ve also tried calling comp.Params.Output[i].Attributes.RespondToMouseDown(sender, e);
directly from the component’s mouse event handler, but that didn’t work either and also feels a little hacky.
If I modify the component’s isPickRegion
to return false
if the mouse is on one of the parameters the mouse events get handled by the parameters, but then of course I cannot catch my double click anymore
Any suggestions are greatly apprechiated!
Best and thanks again,
Paul
