I am trying to use a grasshopper file containing a custom C# goal by Daniel Piker.
I hadn’t experienced any issues opening the file before; now I need a little bit of help.
First, the C# goal says KPlankton isn’t found:
- Error (CS0246): The type or namespace name ‘KPlankton’ could not be found (are you missing a using directive or an assembly reference?) (line 27)
Not sure what this means, I do have Plankton in my library folder
If I open the code and delete line 27, following a similar issue in a different thread, then I get this other warning:
- Warning (CS1701): Assuming assembly reference ‘RhinoCommon, Version=5.1.30000.13, Culture=neutral, PublicKeyToken=552281e97c755530’ matches ‘RhinoCommon, Version=6.34.21034.7001, Culture=neutral, PublicKeyToken=552281e97c755530’, you may need to supply runtime policy
Not sure what this means either, yet following another similar thread, I right-click the C# goal and go to “Manage assemblies”, where I click ‘add’ to then specify the current kangaroosolver.dll location.
Warnings go away and the C# goal looks ‘normal’:
Nonetheless, the kangaroo solver does not seem to accept said goal:
I have Rhino 6, 7, and WIP installed, with no .dll or .gha warnings when I open them separately.
My Libraries folder shows the following kangaroo-related .dlls and .ghas:
I believe this is happening with any C# goal going into kangaroo, as I am experiencing this with more than one file.
How can I solve this issue? Is this related to having multiple installs?
Thank you for your feedback
