Custom Goal Scripting with new Editor - Manage Assembly
@DanielPiker
How can I access Manage Assembly for the new RhinoCode-c# Editor ?
mac os x 13.5.1 (22G90)
Version 8 WIP (8.0.23241.14306, 2023-08-29)
I wanted to adapt some of the nice examples
using the new Script-Editor RhinoCode in Grasshopper, Mac.
The old Editor had Manage Assembly on the right-mouse-menu.
How can I access Manage Assembly for the new Editor ?
Errormessage
The type or namespace name 'KPlankton' could not be found (are you missing a using directive or an assembly reference?)
The type or namespace name 'KangarooSolver' could not be found (are you missing a using directive or an assembly reference?)
for older versions / the old editor this is solved:
THANKS
EDIT:
here is copy of an easy example … new editor not working… missing assembly
CustomGoal_01_WIPV8.gh (18.6 KB)
or
@eirannejad
can you help ?
Hello @Tom_P
This involves loading the DLL in the context.
in C#/Rhino there is only one context.
  • So what is loaded by Grasshopper is accessible by Rhino.
  • What is loaded by Rhino can be accessed by Grasshopper.
  • What is loaded by any means is accessible everywhere (Rhino/Grasshopper).
(I have not tested the following for you, this is under user expert control).
But a workaround could be:
  • Use Assembly.LoadFrom (You can call it multiple times, just one DLL and those dependencies will be loaded)
  • or you can use a Grasshopper script node to load the DLL (the old editor with Manage Assembly).
If this doesn’t work, it’s because the new editor doesn’t build the C# code with the same dependencies as Rhino (Like the old editor).
So this would be a feature request to make.
jmv.
@Tom_P
add this to the top of your script
// r "path/to/your/Library.dll"
It works similar to specifying Nuget packages and already loaded assemblies:
// r nuget "RestSharp==106.12.0"
// r "System.Text.Json"
how to do it in c# ?
how !! I didn’t know you supported this directive! This makes me want to install Rhino 8.
Hello @Tom_P
you can do it like this, at the top of your file:
#r "C:\Program Files\Rhino 7\System\websocket-sharp.dll"
#r "nuget:Newtonsoft.Json/9.0.1"
Hello @eirannejad
Do you support the #load directive?
And is it possible to load a DLL compiled with RhinoCode into another script?
Let me explain, for the moment I use my own editing system.
The implementation is different from RhinoCode but the objective is the same.
I often have standalone scripts that I would like to link to other scripts.
I use Roslyn Script Compilation which embeds the code in a state machine and makes it difficult to access.
This is problematic, because the only way to include script A in another is to use the #load directive.
This involves having to recompile all scripts that depend on script A.
I haven’t tried RhinoCode in a long time, I will, but in my experience it would be very convenient if the DLLs generated by RhinoCode could be linked with the #r directive.
it’s the case ?
THANKS
this works for me now under mac os x - great:
#r "/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Versions/A/Resources/ManagedPlugIns/GrasshopperPlugin.rhp/Components/KangarooSolver.dll"
using System;
using System.Collections.Generic;
using Rhino;
using Rhino.DocObjects;
using Rhino.Collections;
using Rhino.Geometry;
using Grasshopper;
using Grasshopper.Kernel;
using Grasshopper.Kernel.Data;
using Grasshopper.Kernel.Types;
using KPlankton;
using KangarooSolver;
using KangarooSolver.Goals;
working example with comments
CustomGoal_newEditor.gh (20.7 KB)
I have an additional question regarding this topic. With the earlier version of the code editor, I got IntelliSense for the added DLL. Is there any way I’m able to have this in the new editor?
@eirannejad please have a look at this even if I marked the topic as solved.
I have an additional question about this way of referencing the dll. As I understand it, such references cannot be set inside the program using variables? So when opening the file using another instance of Rhino or another computer, is there a way to avoid manually going into every custom goal and changing the filepath? I am making a definition that other people will have to use regularly, and this would be very cumbersome.
I am not sure what do you mean by “goal”. If you want to reference and load a dll in a script that runs on multiple machines, that dll needs to be in an accessible shared location, or be on NuGet
By goal I mean a kangaroo goal, which uses the KangarooSolver.dll. Previously, the script component asked you to manually select a new file path if the file seemed missing. This makes sense in Grasshopper with so many commonly accessible plugins that are locally saved. Even with an accessible shared location, dropbox, for example can have different file paths to the same file for different users.
This means that now, if you have scripts referencing dlls, you either have to upload them to nuget, which could have some legal and security issues(?) and require an internet connection, set up a commonly accessible file with the same file path for every user, or in many cases go into every script component and change the file path manually when using the definition. Including instructing people with no knowledge or interest of doing so.
This would be much easier if grasshopper had a folder where you could put dlls, a bit like the component folder, that enables referencing them in scripts without manually setting the whole path.
if installed via package manager - check:
/Users/<your username>/Documents/Library/Application Support/McNeel/Rhinoceros/packages/8.0
I think i´ve got the same problem, but i dont get it solved. The only reason i can think of that it doesnt work, is because i use the rhino 90 day free trial version. Is it possible, that because of that i can´t load the KangarooSolver.dll ?
I placed this in the beginning of my script : // r “C:\Program Files\Rhino 8\Plug-ins\Grasshopper\KangarooSolver.dll”
thats the path i looked up to find the dll file.
And i still get the Error: : The type or namespace name ‘GoalObject’ could not be found (are you missing a using directive or an assembly reference?)
Does anyone have a further idea for this problem?
Hi all, I also need some help to convert this old node to the new C# component (it is an upgrade of the native hinge node that prevents the fold to get crazy when it touches 180° fold angle).
I’m not expert of C# and whatever I do it gives me errors.
C# new conversion.gh (7.8 KB)
Hi @riccardo.foschi2
Here’s that script converted to the new C# editor component:
C#converted.gh (15.3 KB)
The main difference is that when setting the reference, instead of using the old way of right clicking>manage assemblies>adding the explicit file location, you can just add these lines below the other ‘using’ statements:
#r "KangarooSolver.dll"
@Lukas_Radermacher Sorry I missed your reply earlier - It should work as usual in the trial version, using the above way of setting the reference.
Thank you very much it works perfectly!
