C# Component Not working as expected Using Rhino.Insde Revit
Hi Community
I was updating some of my old scripts to work with Rhino 8. Most of my scripts work for Grasshopper and also they work for Grasshopper using Rhino.inside Revit.
I have an interesting behavior with the C# Script for Rhino 8.
Below you can see a C# capsule that is working totally okay with Grasshopper using Rhino 8
Where things get interesting are when I try to use the same c# script opening Revit and then Rhino.Inside. The same exact script gives me an error for the reference.
I think there is something going on with c# component in Grasshopper using Rhino.Inside.
Did anyone else had similar issues?
I am using Revit 2024
Rhino Inside Revit version
Attached are my grasshopper file and the DLL I am referencing. I think it is not an issue with the DLL itself.
Archive.zip (118.4 KB)
Thanks in advance
@Japhy and @eirannejad have you experienced this behavior?
@rolandoavillena1 Would you mind testing this in latest Rhino 8.14 SRC and RHINO.INSIDE.REVIT? I just tested and your component runs with no errors in both Revit 2024 and Revit 2025 (dotnet core)
@eirannejad For the latest Rhino.inside Revit do you recommend v1.26 or v1.27 RC1
Try 1.27 RC
@eirannejad, I have a corporate machine so it is difficult to get the Rhino 8.14 SRC version and the Rhino Inside Revit 1.27 RC
I have tested with Rhino 8 SR13 and Rhino inside Revit v1.26 and the problem persists.
I’ll try to test on my own personal computer later today and report back.
Thanks
