Rhino inside issue with script component
Hey , when I run rhino inside and try on script component in Rhino8 , this error appears! . when I use scripts component in normal opening rhino8 , it works correctly. what is wrong?
Hi Hnazari 8983
Is the Rhino.Inside.Revit or a custom implementation?
Please provide SystemInfo and more detail, thanks!
https://discourse.mcneel.com/t/help-us-help-you-rhino-inside-revit-edition/170291/3
No , it’s not the rhino inside component , in Rhino 8 , we have script component which we have choose to select python or C# for coding , I wana code in rhino inside environment. does it make sense?
Not really, but that ok.
Here are our Rhino.Inside examples and Developer Documentation
Apologies, please run SystemInfo in the Rhino command line. Thanks
