Bypassing GH with plug-in development
This is a little beyond me.
I came across this “Rhino.Inside®.Revit” and it works perfectly.
I’m currently interesting if it is possible to bypass grasshopper?
In other words, I am wondering if it is currently feasible or possible to write a dll that will pick up on the RiR thread in Revit and allow you to create custom buttons that see the rhino window (for example, it would allow you to select a revit object and push it into rhino). Along with the inverse (for example, a command that would allow you to pull rhino objects into revit).
Cause the install file is named in a way that makes me think that only on launching Grasshopper is the .gha file read, although, obviously the link already exists between the two.
If it is possible does anyone have a template?
