[BUG?] RiR loading
When launching rhino.inside.revit.
If drag&drop grasshopper that contains revit components onto the rhino window, it looks like it doesn’t load the plugin correctly (see image).
If from rhino, I open grasshopper first, then drag the .gh file on the grasshopper window, all’s fine.
RiR: RhinoInside.Revit_1.28.9138.27861
Rhino: 8 SR16 from 2025-01-28
Thanks for reporting. Seeing this as well.
I have also noticed that when I first launch Rhino Inside Revit and run a Grasshopper Player script it gives me the same ‘Unrecognized Objects’ window then Revit sometimes crashes. The temporary solution I’ve found is to load then Grasshopper interface first then close it, then the Grasshopper Player scripts will work.
This sounds similar to above but a few tries in Revit 2024.3 were unsuccessful in repeating. If you find a repeatable pattern please let us know the steps. Thanks!
I am actually using Revit 2023 just because we have many projects still on that version so I wanted the scripts to work for these projects as well. If that’s fixed in later version then it’s not a huge problem. Thanks Japhy :slight_smile:
I am experiencing the same issue as Diana - running a GH player script and then getting unrecognized components for RIR - but on revit 2024
RIR version
Rhino version
Revit Version
Hi Irayap28, It looks like you are on Rhino 8 SR 12, lets get you on the latest service release.
https://www.rhino3d.com/download/rhino/latest/
Just to confirm actually, I was using Rhino 8 SR10, I will also test once I upgrade mine.
