Button Editor always crashes rhino
Anytime I try to close the button editor, Rhino crashes. Doesn’t matter if I click cancel or ok or the X in the corner.
9.0.26097.12305, 2026-04-07
Do you get a crash report window @phcreates ?
If so can you include your email and send the crash report please and I’ll get that crash fixed.
No crash window, Rhino just closes, even if there is unsaved geometry. I get a little blue wheel for a few seconds and then it just shuts down. Restarting computer didn’t affect it.
System info:
Rhino 9 SR0 2026-4-7 (Rhino WIP, 9.0.26097.12305, Git hash:master @ b60dd410008243ac590db0c97997566b52def575)
License type: Commercial, build 2026-04-07
License details: Cloud Zoo
Expires on: 2026-05-22
Windows 11 (10.0.26200 SR0.0) or greater (Physical RAM: 32GB)
.NET 9.0.1
Computer platform: DESKTOP
Standard graphics configuration using DirectX
Primary display: NVIDIA GeForce RTX 3060 (NVidia) Memory: 12GB, Driver date: 1-20-2026 (M-D-Y). DirectX(11)
Accelerated graphics device with 4 adapter port(s)
  • Secondary monitor attached to adapter port #0
  • Windows Main Display attached to adapter port #1
Secondary graphics devices.
None found.
DirectX Settings
Safe mode: Off
OpenBLAS: OpenBLAS 0.3.30 DYNAMIC_ARCH NO_AFFINITY SkylakeX MAX_THREADS=64.
C:\Program Files\Rhino 9 WIP\Plug-ins\Commands.rhp “Commands” 9.0.26097.12305
C:\Program Files\Rhino 9 WIP\Plug-ins\rdk.rhp “Renderer Development Kit”
C:\Program Files\Rhino 9 WIP\Plug-ins\UpdatesAndStatistics\UpdatesAndStatistics.rhp “UpdatesAndStatistics” 9.0.26097.12305
C:\Program Files\Rhino 9 WIP\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 9.0.26097.12305
C:\Program Files\Rhino 9 WIP\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 9.0.26097.12305
C:\Program Files\Rhino 9 WIP\Plug-ins\NamedSnapshots.rhp “Snapshots”
C:\Program Files\Rhino 9 WIP\Plug-ins\MeshCommands.rhp “MeshCommands” 9.0.26097.12305
C:\Program Files\Rhino 9 WIP\Plug-ins\IronPython\RhinoDLR_Python.rhp “IronPython” 9.0.26097.12305
C:\Program Files\Rhino 9 WIP\Plug-ins\RhinoCycles.rhp “RhinoCycles” 9.0.26097.12305
C:\Program Files\Rhino 9 WIP\Plug-ins\3dxrhino.rhp “3Dconnexion 3D Mouse”
C:\Program Files\Rhino 9 WIP\Plug-ins\Displacement.rhp “Displacement”
C:\Program Files\Rhino 9 WIP\Plug-ins\SectionTools.rhp “SectionTools”
Ok I’ll try and reproduce this and get this fixed, sorry for the bother, but thanks for testing and reporting!
Ticket : RH-94605 Button Editor always crashes rhino
@phcreates I do not get a crash. Can you run OptionsExport and give me your .rhs file?
Anonymous Upload link
Uploaded. Oh - there’s also a RhinoDotNetCrash.txt on my desktop - maybe related to this. I’ll attach it here.
RhinoDotNetCrash.txt (2.0 KB)
That file is very handy. I should have this fixed up for the next release.
If you’d like to get rhino to work for now, it’s worth noting you have two RUIs with identical IDs (GG_Sculpting _Toolbar) and (GG_Sculpting _Tool). If you right click SaveAs for one of these, close the original and open the new Save’dAs one you’ll have no further issues.
I’ve tried to prevent RUIs with the same ID wherever possible as it causes some weird issues I’d like to avoid.
Thanks, BUT, when I run Toolbar and then right-click on a selected toolbar and choose Save File As, it actually doesn’t save the one that I selected - it saves a different toolbar.
I have just renamed one of the sculpting toolbars in its folder for now & haven’t re-opened it (I don’t need it anytime soon) so that has solved the crash problem for now.
Video…(no matter which toolbar I right-click and Save File As, the Save box always prefills with the wrong toolbar name, and I’m pretty sure it actually does save the named toolbar, not the one I selected.)
Ah yes another bug. Until the next release then
I very much appreciate your patience @phcreates !
RH-94605 is fixed in Rhino WIP
@phcreates
I fixed the right click and crash issue, let me know if you’re all set now. I really appreciate you reporting all of the issues you run into, it helps a lot!
@CallumSykes Unfortunately, when I close the edit dialog box, Rhino also closes all of my custom toolbars now.
Todays build should fix this!
RH-94769 Custom Toolbars closed
