Build 499 - Curve Through Points does not work
Control Point Curve works fine, Curve Through Points does nothing.
it works for me… are you selecting points to run the curve through with CurveThroughPt ?
are you sure you’re not confusing it with InterpCrv? (curve: interpolate points)
Thanks, “operator error” on my part. I presumed that corners of rectangles and line segment endpoints were points. No, you need to actually use the point tool to add points!
ha. yeah.
fwiw, there’s another command to use in the rectangle situation:
CurveThroughPolyline
