Bug - Wall layer offset value changes from negative to positive
In a situtation where wall layer offset value is set to a negative value (ie: -0.3, overwritten the style) when I move or copy the wall instance, the offset value turns to positive. ( ie: 0.3) Attached is the example file.
Best,
Ahmet
Bug-WallLayerNegativeValue.3dm (3.1 MB)
Hi @ahmet.unveren
Thanks for reporting this issue.
We will let you know when it is fixed.
Kind regards
Hi @ahmet.unveren!
This bug has been fixed in VisualARQ 2.8: VisualARQ 2 - Version 2.8 released
