Bug(?) - switch mode of extract surface cause end of the process
if I started to extract some surfaces from a polysurface and like to switch from copy to non copy mode, than the current selected surfaces are extracted and the command is finished. Could be great if the mode can be switched without to finish the process. Old issue bother me since years. :wink:
-Micha
That bothered me for a long time too but this has been fixed. Not sure if it was fixed in RH5 but definitely in RH6. What SR of RH5 are you running?
For RH6 fixed - that’s fine. Current I work at RH5 SR14.
Thanks,
Micha
