Bug ? Sub-vertices selection on polysurface
There seems to be a small problem with the highlight for sub-objects on polysurfaces.
Despite zooming and being close to the vertex, this sub-object is never offered as a selection, the edges are always highlighted.
It does work on SubDs as intended.
It is possible to sub-object-select vertices by doing a window selection but that is not very practical.
thanks for reporting. This seems to be not working as intended.
RH-75852 SubObject selection / Mouseover highlight does not work for (poly)surface vertices
RH-75852 is fixed in the latest WIP
Thanks !
