(7.0.20119.13305, 4/28/2020)
RH6_AND_7.3dm (107.1 KB)
Hi @PowerShape, if you manage to select the result, run _RebuildMesh
to fix the selection and clipping problem.
@pascal, i remember that i reported this to tech 4 years ago but i cannot find the youtrack item for it. Could you make an item for it please ?
_
c.
@PowerShape, @clement - there is a bug here that is likely the same thing:
RH-48452 Squish result hides
but I added a new YT because this behaves slightly differently - works after a save/reopen, here.
RH-58242 Squish output is clipped and not selectable
(as an aside, it helps to UnweldVertex
a vertical row of vertices on the cone before Squishing - the resulting shape makes more sense)
RH-58242 is fixed in the latest Rhino 7 Service Release Candidate
