Bug | Sections | Print preview
It seems there is a bug with print preview. Print preview is displaying correctly only after opening a file. After, for example switch on/off print preview/ panning, zooming action - is no longer working.
Please see below.
Thank you.
Tomas
RH8 SR8
Hi Tomas -
I really don’t know what I’m looking at here, and what is right and what is wrong. Please post both the output of the Rhino SystemInfo command and a 3dm file that exhibits an issue.
@wim Hi Wim, please any solution to fix it? Basically, print preview works in viewport but not in layout. ?
Hi @wim , please any update on this issue? Thanks. Tomas
I’ll take a look but will need more information, a small example file and steps to repeat ideally. Thanks
Hello @Japhy, thank you. The file is attached in the message. I am encountering the same issue across several different files. Tomas
Please run SystemInfo in your Rhino command line and post the result. Thanks!
Rhino 8 SR10 2024-7-23 (Rhino 8, 8.10.24205.13001, Git hash:master @ 20bc3267cc7d3ea766e91bec2ff8ef5ff8fb1755)
License type: Commercial, build 2024-07-23
License details: Stand-Alone
Windows 11 (10.0.22631 SR0.0) or greater (Physical RAM: 32GB)
.NET 7.0.20
Primary display: Intel(R) Iris(R) Xe Graphics (Intel) Memory: 1GB, Driver date: 10-6-2023 (M-D-Y).
- Laptop lid is possibly closed
- Windows Main Display attached to adapter port #2
Primary OpenGL: NVIDIA GeForce RTX 3070 Ti Laptop GPU (NVidia) Memory: 8GB, Driver date: 2-15-2024 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 551.61
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 2-15-2024
Driver Version: 31.0.15.5161
Z-Buffer depth: 24 bits
Total Video Memory: 8 GB
C:\Program Files\Rhino 8\Plug-ins\Tibidabo\Tibidabo.rhp “Tibidabo”
C:\Program Files\Rhino 8\Plug-ins\Tibidabo\VisualARQ.rhp “VisualARQ”
C:\Program Files\Enscape\Enscape.Rhino.Plugin-net48\Enscape.Rhino8.Plugin.dll “Enscape.Rhino8.Plugin” 0.0.24068.1709
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.10.24205.13001
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.10.24205.13001
C:\Program Files\Rhino 8\Plug-ins\RhinoRender.rhp “Legacy Rhino Render”
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.10.24205.13001
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.10.24205.13001
C:\Program Files\Rhino 8\Plug-ins\IronPython\RhinoDLR_Python.rhp “IronPython” 8.10.24205.13001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.10.24205.13001
C:\Program Files\Rhino 8\Plug-ins\Grasshopper\GrasshopperPlugin.rhp “Grasshopper” 8.10.24205.13001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.10.24205.13001
C:\Program Files\Rhino 8\Plug-ins\NamedPositions.rhp “Named Position”
I’ll need steps to repeat the regression to file a bug report.
This file behaves the same in Rhino 8 & 7 as far as i can tell.
I have tested various files and noticed that the clipping sections do not display correctly in the print preview. Although the color is ignored, after printing to PDF, they are correctly displayed.
