Recently right-clicking on Model Attribute Key stopped bringing up the context menu.
The context menus still come up for the other inputs on these components, and similar menus for other components from the Rhino tab in Grasshopper work normally.
The first time I noticed this was after the update that added the UserText expression to the key input, but it could have changed before that.
Is this a bug, or a new feature/work flow that I’m using the wrong way? Here’s a grasshopper file and my system info.
Key right click not working.gh (15.9 KB)
System Info
Rhino 8 SR9 2024-6-19 (Rhino 8, 8.9.24171.03001, Git hash:master @ c7bc7dce8c2b456b3f0c5f0fa669295aa802ef1a)
License type: Commercial, build 2024-06-19
License details: Cloud Zoo
Windows 11 (10.0.22631 SR0.0) or greater (Physical RAM: 16GB)
.NET 7.0.14
Primary display: DisplayLink USB Device (DisplayLink) Memory: 0MB, Driver date: 9-26-2023 (M-D-Y).
> External USB display device with 4 adapter port(s)
- Secondary monitor attached to adapter port 0
- Windows Main Display attached to adapter port 1
Primary OpenGL: NVIDIA Quadro T2000 (NVidia) Memory: 4GB, Driver date: 1-2-2024 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 538.18
Secondary graphics devices.
> External USB display device with 0 adapter port(s)
- There are no monitors attached to this device. Laptop lid is probably closed
Intel(R) UHD Graphics 630 (Intel) Memory: 1GB, Driver date: 11-15-2021 (M-D-Y).
OpenGL Settings
Safe mode: Off
Anti-alias mode: 8x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 1-2-2024
Driver Version: 31.0.15.3818
Z-Buffer depth: 24 bits
Total Video Memory: 4 GB
C:\Users\dunca\AppData\Roaming\McNeel\Rhinoceros\packages\8.0\NVIDIADenoiser\0.4.3\NVIDIADenoiser.Windows.rhp “NVIDIADenoiser.Windows” 0.4.3.0
C:\Users\dunca\AppData\Roaming\McNeel\Rhinoceros\BlockEditNew\BlockEditNew_V8.rhp “BlockEdit” 1.0.0.0
C:\Users\dunca\AppData\Roaming\McNeel\Rhinoceros\8.0\Plug-ins\SpeckleRhino2 (8dd5f30b-a13d-4a24-abdc-3e05c8c87143)\SpeckleConnectorRhino.rhp “SpeckleConnectorRhino” 2.19.1.15397
C:\Users\dunca\AppData\Roaming\McNeel\Rhinoceros\packages\8.0\Fenix\2.0.0.4\FenixToolbar.rhp “FenixToolbar” 2.0.0.4
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.9.24171.3001
C:\Program Files\Rhino 8\Plug-ins\AnimationTools.rhp “AnimationTools”
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.9.24171.3001
C:\Program Files\Rhino 8\Plug-ins\RhinoRender.rhp “Legacy Rhino Render”
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.9.24171.3001
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.9.24171.3001
C:\Program Files\Rhino 8\Plug-ins\IronPython\RhinoDLR_Python.rhp “IronPython” 8.9.24171.3001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.9.24171.3001
C:\Program Files\Rhino 8\Plug-ins\Grasshopper\GrasshopperPlugin.rhp “Grasshopper” 8.9.24171.3001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.9.24171.3001
