Hello, I just updated to the latest WIP build 4/25/23 and all of the “Objects” category nodes in Grasshopper under the new Rhino tab no longer work with the exception of “Model Object” and “Query Model Objects”
Error: 1. Solution exception:Object reference not set to an instance of an object.
Steps to reproduce:
-Open new grasshopper window in any Rhino file (new or old)
-Drag any of the problemed nodes onto the canvas
To expand on this, it appears to be related to the nodes not accepting null values, at least partially.
Please see the image here where I can get the node “enabled” by passing in a null value.
Please note that while this removes the error it does not make the node function correctly as the boolean toggle example still returns a null value on the “get” side of the pass-through node.
