Repostin - not sure I posted in correct place previously. I am opening a previously perfectly functional grasshopper definition in Rhino Inside Revit and all the components suddenly fail and give the exception “Object reference not set to an instance of an object.” This only happens with a very large Revit model that is hosted on an external server. When I open the Revit sample test model the grasshopper definition works fine and does not throw this error. I have recently updated both Rhino 7 and Rhino.Inside.Revit. Am dead in the water with this issue - any ideas how to fix it?
Thanks
Hi - the Revit model was exported from BIM 360 cloud server to our firm’s local server (remote to me but part of our office network). I was trying to run Rhino.Inside on the copy of the file (running through a VPN connection), not directly from the BIM 360 version.
Hi - still getting this problem with a large revit model. I have downloaded the model to my local drive and tried there, with no improvement. Grasshopper gives these component exception errors for every component, then freezes completely.
