Bug: V8 WIP get something wrong in the latest WIP in rhino components
Please see below, in the latest WIP, the components shown are got red and not working. And they all get the warning tips for “1. Solution exception:Object reference not set to an instance of an object.”
They added a bug tracker for this issue, please see post:
Here’s the bug tracker: https://mcneel.myjetbrains.com/youtrack/issue/RH-74611
Thanks a lot, I just rollback to version 8.0.23101.16305 that the components in it can be run well. :joy:
How do you roll back to a previous version?
You may still have it in your %userprofile%\Appdata\local\McNeel\McNeelUpdate\DownloadCache\ folders
Bear in mind that WIPs expire after six or seven weeks, so there’s a limit to how far back it is viable to go.
HTH
Jeremy
Thanks I’ll check that out!
