Bug report - layout pages disappearing in layout panel
Rhino 8 on mac. this started happening a few weeks ago, perhaps after the latest update.
Sometimes, for no discernible reason, the layouts panel just goes empty.
The layout still exist, I just can’t navigate to them. Closing and re-opening the file brings it back.
Has happened on many different files so not file specific.
Usually, the entire window sort of whites out and “refreshes” right before the pages disappear, like it’s about to crash but doesn’t.
System info:
Rhino 8 SR37 2026-11-3 (Rhino 8, 8.37.26307.15002, Git hash:master @ c4477bc788d7c2a5b543b0cd917f0dde91849957)
License type: Commercial, build 2026-11-03
License details: Cloud Zoo
Apple macOS Version 26.5.2 (Build 25F84) (Physical RAM: 128GB)
Mac Model Identifier: MacPro7,1
Language: en-US (MacOS default)
.NET 10.0.8
Metal GPU Family Apple 0
Metal GPU Family Common 3
Metal GPU Family Mac 2
Graphics processors
AMD Radeon Pro W5700X (16 GB)
DELL E2222HS (1920 x 1080 @ 60.00Hz)
Acer K202HQLA (1366 x 768 @ 60.00Hz)
GPU Vendor: AMD
USB devices
Apple Inc.: USB-Serial (0001)
VIA Labs, Inc.: USB3.0 Hub
Generic: HD camera
Chrontel: Billboard
Apple: Headset
Apple Inc.: Apple T2 Controller
Bluetooth devices
None
Third party kernel extensions
None
Third party plugins
/usr/lib/swift/libswift_Builtin_float.dylib
/usr/lib/swift/libswift_DarwinFoundation1.dylib
/usr/lib/swift/libswiftDistributed.dylib
/usr/lib/swift/libswiftObservation.dylib
/usr/lib/swift/libswiftSynchronization.dylib
/usr/lib/swift/libswiftVideoToolbox.dylib
/usr/lib/swift/libswift_DarwinFoundation2.dylib
/usr/lib/swift/libswift_DarwinFoundation3.dylib
/usr/lib/swift/libswiftNaturalLanguage.dylib
/usr/lib/swift/libswiftMLCompute.dylib
/usr/lib/swift/libswiftSpatial.dylib
/usr/lib/swift/libswiftFoundation.dylib
/usr/lib/swift/libswiftSwiftOnoneSupport.dylib
/usr/lib/swift/libswiftsys_time.dylib
/usr/lib/usd/libusd_ms.dylib
/usr/lib/swift/libswift_errno.dylib
/usr/lib/swift/libswiftCoreMediaIO.dylib
/usr/lib/swift/libswiftCallKit.dylib
/usr/lib/swift/libswiftPassKit.dylib
/usr/lib/swift/libswiftAppleArchive.dylib
/usr/lib/updaters/libAppleTconUARPUpdater.dylib
/usr/lib/swift/libswiftGLKit.dylib
/usr/lib/swift/libswiftMetalKit.dylib
/usr/lib/swift/libswiftModelIO.dylib
/usr/lib/swift/libswiftSceneKit.dylib
/usr/lib/swift/libswiftExtensionFoundation.dylib
/usr/lib/swift/libswiftGameplayKit.dylib
/usr/lib/swift/libswiftSpriteKit.dylib
/usr/lib/swift/libswiftMapKit.dylib
/Applications/Rhino 8.app/Contents/Frameworks/RhMaterialEditor.framework “Renderer Development Kit” 8.37.26307.1002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Commands.rhp “Commands” 8.37.26307.15002
/Applications/Rhino 8.app/Contents/PlugIns/NamedSnapshots.rhp “Snapshots” 8.37.26307.1002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RDK_EtoUI.rhp “RDK_EtoUI” 8.37.26307.15002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/MeshCommands.rhp “MeshCommands” 8.37.26307.15002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/export_PDF.rhp “PDF Export” 8.37.26307.15002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/BlockEdit.rhp “BlockEdit” 8.37.26307.15002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoRenderCycles.rhp “Rhino Render” 8.37.26307.15002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoCycles.rhp “RhinoCycles” 8.37.26307.15002
/Applications/Rhino 8.app/Contents/PlugIns/AnimationTools.rhp “AnimationTools” 8.37.26307.1002
/Applications/Rhino 8.app/Contents/PlugIns/SectionTools.rhp “SectionTools” 8.37.26307.1002
/Applications/Rhino 8.app/Contents/PlugIns/RhinoRender.rhp “Legacy Rhino Render” 8.37.26307.1002
/Applications/Rhino 8.app/Contents/PlugIns/Displacement.rhp “Displacement” 8.37.26307.1002
/Applications/Rhino 8.app/Contents/PlugIns/PanelingTools.rhp “PanelingTools” 8.37.26307.1002
/Applications/Rhino 8.app/Contents/PlugIns/SolidTools.rhp “SolidTools” 8.37.26307.1002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoDLR_Python.rhp “IronPython” 8.37.26307.15002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/GrasshopperPlugin.rhp “Grasshopper” 8.37.26307.15002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoCodePlugin.rhp “RhinoCodePlugin” 8.37.26307.15002
Hi @Nikki4,
Not much to go on.
  1. Does it seem to happen after the displays sleep/wake, or when a monitor is connected, disconnected or changes resolution?
  2. Is the Layouts panel docked or floating? If you close it and open it again (without closing the file), do the layouts come back?
  3. Do you have more than one file open when it happens?
  4. While the panel is empty, can you still switch layouts with the Layout command or the viewport tabs?
  5. Anything you usually do just before it happens (Print, PDF export, Undo, switching apps)?
If you can catch it happening, a short screen recording would help a lot.
Thanks,
– Dale
I know it’s not a lot of details, sorry, I haven’t figured out the common factor in this issue.
It was getting particularly bad this morning, I was continually closing and re-opening the same file and losing access to layouts, I restarted Rhino and my computer and it’s been less frequent since.
  1. I always have monitors connected, I don’t disconnect them, it’s a desktop. No connection to sleep wake or resolution. it will literally happen in the middle of editing a file. I thought it was connected to this new rhino “refresh” behavior I’ve been observing but it’s also been happening on its own. Nothing about my monitors appears to be changing, it’s just the rhino window. I think the “refresh” where the entire window whites out is related to turning on print display.
  2. I have tried both. I usually keep it docked, but I have also had it happen on a floating panel at the same time.
  3. Yes, I am usually working on multiple files at once.
  4. Since I’m on mac, I can’t switch from the viewport ribbon like I can on PC. The “layout” command just makes a new layout as far as I know? and “layouts” just navigates me to the layout panel. Maybe I’m missing something but the layouts panel is the only way I know how to navigate between layouts on mac
  1. I have been unable to isolate it, I don’t think it’s switching apps. I notice it happening when I’m in layout because that’s when I have the layout tab up and notice my inability to navigate.
Of course once I try and replicate it, it stops happening. Ugh. I doubt I could get a screen recording since I don’t know what triggers it, unless I just continually recorded my screen and hoped it would happen. But all it would show is that the layouts panel just goes from having layouts to having none, even if I’m currently in a layout. I’ll update if I have further info.
