I was having massive crashes with Rhino8 for Mac working with layouts. It was definitely a hefty file (20 layout pages (1–3 detail views per page, ghosted mode, showing 3D models) but it worked fine on my PC. On my Mac, most layout changes caused the spinning wheel of death. Duplicating a layout would make Rhino not respond for 5-10minutes, sometimes having to force quit.
Changing the Rhino settings didn’t help. I did use claude for debugging this FYI. I ran a “sample” process from activity monitor while Rhino was crashing and fed it in - it figured out that it was one of my panels causing the issue. Sample output attched. Once I closed all my panels except for “Layout,” duplicating a layout page went from freezing my Rhino to successfully duplicating in about 5sec.
Sample of Rhino 8.txt (1.2 MB)
Ok I’ll just paste in from claude now, sorry, I don’t understand it enough to say in my own words.
Ruled out:
Memory: no memory pressure during the freeze (confirmed in Activity Monitor)
Mesh/render quality: switching to “Faster and coarser” made no difference
GPU: single-core CPU spike, not GPU-bound; ruled out via Activity Monitor CPU/GPU history
Root cause (found via sample on the frozen process):
The freeze traces to CCommandCopyLayout::RunCommand → CRhinoDoc::AddObject → CRhinoLayerTable::ModifyLayer, which fires a layer-table change event. That event triggers a full -[NSOutlineView reloadData] on a panel’s outline view — almost certainly the Layers panel — which then tears down and rebuilds every row view from scratch: hundreds of NSTextField/NSTextFieldCell allocations, each registering/unregistering weak references, KVO observers, and Auto Layout constraints, one row at a time, on the main thread.
SystemInfo:
Rhino 8 SR35 2026-9-8 (Rhino 8, 8.35.26251.13002, Git hash:master @ 3645d710f50175d8ebcf404aded5b042a481c23e)
License type: Commercial, build 2026-09-08
License details: Cloud Zoo
Apple macOS Version 26.5.2 (Build 25F84) (Physical RAM: 128GB)
Mac Model Identifier: MacPro7,1
Language: en-US (MacOS default)
.NET 8.0.14
Metal GPU Family Apple 0
Metal GPU Family Common 3
Metal GPU Family Mac 2
Graphics processors
AMD Radeon Pro W5700X (16 GB)
DELL E2222HS (1920 x 1080 @ 60.00Hz)
Acer K202HQLA (1366 x 768 @ 60.00Hz)
GPU Vendor: AMD
USB devices
Apple Inc.: USB-Serial (0001)
VIA Labs, Inc.: USB3.0 Hub
Generic: HD camera
Chrontel: Billboard
Apple Inc.: Apple T2 Controller
Apple: Headset
Bluetooth devices
None
Third party kernel extensions
None
Third party plugins
/usr/lib/swift/libswift_Builtin_float.dylib
/usr/lib/swift/libswift_DarwinFoundation1.dylib
/usr/lib/swift/libswiftDistributed.dylib
/usr/lib/swift/libswiftObservation.dylib
/usr/lib/swift/libswiftSynchronization.dylib
/usr/lib/swift/libswiftVideoToolbox.dylib
/usr/lib/swift/libswift_DarwinFoundation2.dylib
/usr/lib/swift/libswift_DarwinFoundation3.dylib
/usr/lib/swift/libswiftNaturalLanguage.dylib
/usr/lib/swift/libswiftMLCompute.dylib
/usr/lib/swift/libswiftSpatial.dylib
/usr/lib/swift/libswiftFoundation.dylib
/usr/lib/swift/libswiftSwiftOnoneSupport.dylib
/usr/lib/swift/libswiftsys_time.dylib
/usr/lib/usd/libusd_ms.dylib
/usr/lib/swift/libswift_errno.dylib
/usr/lib/swift/libswiftCoreMediaIO.dylib
/usr/lib/swift/libswiftCallKit.dylib
/usr/lib/swift/libswiftPassKit.dylib
/usr/lib/swift/libswiftAppleArchive.dylib
/usr/lib/updaters/libAppleTconUARPUpdater.dylib
/usr/lib/swift/libswiftGLKit.dylib
/usr/lib/swift/libswiftMetalKit.dylib
/usr/lib/swift/libswiftModelIO.dylib
/usr/lib/swift/libswiftSceneKit.dylib
/usr/lib/swift/libswiftExtensionFoundation.dylib
/usr/lib/swift/libswiftGameplayKit.dylib
/usr/lib/swift/libswiftSpriteKit.dylib
/usr/lib/swift/libswiftMapKit.dylib
/Applications/Rhino 8.app/Contents/Frameworks/RhMaterialEditor.framework “Renderer Development Kit” 8.35.26251.1002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Commands.rhp “Commands” 8.35.26251.13002
/Applications/Rhino 8.app/Contents/PlugIns/NamedSnapshots.rhp “Snapshots” 8.35.26251.1002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RDK_EtoUI.rhp “RDK_EtoUI” 8.35.26251.13002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/MeshCommands.rhp “MeshCommands” 8.35.26251.13002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoRenderCycles.rhp “Rhino Render” 8.35.26251.13002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoCycles.rhp “RhinoCycles” 8.35.26251.13002
/Applications/Rhino 8.app/Contents/PlugIns/AnimationTools.rhp “AnimationTools” 8.35.26251.1002
/Applications/Rhino 8.app/Contents/PlugIns/SectionTools.rhp “SectionTools” 8.35.26251.1002
/Applications/Rhino 8.app/Contents/PlugIns/RhinoRender.rhp “Legacy Rhino Render” 8.35.26251.1002
/Applications/Rhino 8.app/Contents/PlugIns/Displacement.rhp “Displacement” 8.35.26251.1002
/Applications/Rhino 8.app/Contents/PlugIns/PanelingTools.rhp “PanelingTools” 8.35.26251.1002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoDLR_Python.rhp “IronPython” 8.35.26251.13002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/GrasshopperPlugin.rhp “Grasshopper” 8.35.26251.13002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoCodePlugin.rhp “RhinoCodePlugin” 8.35.26251.13002
