Has anyone noticed that a clipping plane hides points that are inside of blocks (although the entire block should be visible)?
Block with Clipping place active in view
Block with Clipping plan not active in view
Hello - I do not see that here in the latest - can you please run SystemInfo
in Rhino and post the results?
SystemInfo.txt (2.0 KB)
Hi Kevin - I’d try to get an updated video driver installed if that is available:
Driver date: 10-16-2017 (M-D-Y)
Check the Intel website.
Hi @pascal,
Thanks for the update tip.
It did not work…same file, same issue.
The file and new SystemInfo is attached.
pointsInBlockText_R7.3dm (171.0 KB) SystemInfo-postUpdate.txt (2.0 KB)
