Hi! Thanks to Elefront developers for the plugin! Here is a problem:
Bake component does not delete previously baked objects with the same BakeName if the layer is locked. As result Rhino document keeps geometries for each change of inputs.
krahimzadeh
On screenshot: when the toggle == False then everything is fine, but if toggle == True then old geometry is not deleted.
krahimzadeh
(Keyan Rahimzadeh)
April 17, 2024, 9:19pm
2
Okay thanks, I’ll look into it.
Should be resolved in 5.1.9.
eleFront 5.1.9-beta
This update includes a number of fixes. I’m designating it as a ‘beta’ to get feedback on some of the changes.
Bugs resolved in this version:
Previous version did not maintain overrides for Text objects, such as Justification, Size, etc.
Objects on locked Layers not deleted when baking
In some instances, Baking to an external file did not maintain the objects’ attributes
Updates / Changes
The eleFront Layer component has been changed. You can now also pass the componen…
