When I try to rename a Display Mode in Rhino 9 WIP, I can only type the first letter in the Name field. After that, the cursor jumps to the command line, and the remaining letters are typed there instead of in the Name field.
Hi Lazar -
That appears to work fine here.
Please run the Rhino SystemInfo command and copy-paste its output here.
It seems to be working fine on my end. I’ve send the download link for the latest Rhino BETA via DM. Please give it a try when you have a moment. Thank you.
Could you please share this 3dm file? Thank you.
@jessesn I can’t share the 3dm file (the project isn’t public yet), but I don’t think the model itself is relevant to the issue I described. You can try with the simple box as well. The problem seems to be with the display mode.
After I copy it, the copied version looks different from the original.
Here is the display mode file.
Concept_Customized.ini (7.9 KB)
I’d suggest exporting the Concent display mode as an .ini file too, then run it through a diff tool like https://www.diffchecker.com/ to see what’s different. I’m already seeing quite a few differences between your custom file and the default settings, as you can see in the image below.
@jessesn From a broader perspective, don’t you think the copied display mode should look exactly the same as the original right after you copy it?
My issue isn’t with the original Concept display mode.
I first customized it, then copied that customized version. The problem is that the copy looks different from the customized one immediately after copying it (please check the video above).
You’re right. I tested it here - duplicated the Concept display mode and switched back and forth between the default and the copy, and got exactly the same result. I can’t reproduce the issue you mentioned, so could you share your .3dm file so I can take a closer look? Thank you.
You may want to try the comparison tool I suggested earlier, and take a closer look at the differences between your customized Concept display mode and the duplicated copy.
HI -
I’m seeing that issue here so I’ll get this logged.
→ RH-98369 Display: Copy of Concept is Different
Thanks!
