[BUG] R8 keyboard input
I have this weird weird bug happening oh R8 for Mac…
When I type on my AZERTY keyboard the shortcut “z” to call the Zoom command, the Command field inputs a “w” instead, at least 50% of the time :confused:
This is very annoying – and it’s not an OS-related issue, it’s just on R8 – e.g. R7 works as expected.
Edit: It happens really often when I right click on a layer in the Layer Panel, do → Select Objects, and then type “z”, and the command field shows a “w” instead.
@Gijs :slight_smile:
hmm, I don’t have an azerty keyboard here.
@dale I’m tagging you since the user reports this happens after an action in the layer panel
When you type “z”, is the layers panel active? Or is a Rhino viewport active?
– Dale
The viewport
It’d be interesting to know if you get sometimes a q when you type a. I use a non-qwerty layout on all my machines - windows and mac, but I have never seen such behavior. The QWERTY row for me reads PHRK>.
Yes, I just tried to type an A and got a Q instead.
I can easily replicate this behaviour in a particular model I am working on – I PM you.
This can easily be reproduced on MacOS with empty file:
I am able to reproduce this with the following, simpler, steps:
  1. open the 3dm
  2. open layer panel if it isn’t yet
  3. click in layer panel
  4. type p on my key layout
  5. Rhino command line shows a q
My key layout is
This is on Sonoma 14.1.1 with custom key layout as shown above.
Anyone should be able to reproduce by selecting a different key layout, like AZERTY. No need to get a different keyboard for that.
(I’m on Monterey)
To ensure it doesn’t get lost I logged it as: RH-78406 With Layer Panel focused it overrides keyboard layout input
Thanks. I hope it can be solved very soon, it’s pretty crazy not being able to use the zoom shortcut…
Rhino8. My god. Broken gumball, broken graphics, broken UI, even broken keyboard inputs…
Workaround: click in viewport before typing command.
(note, I used word workaround - not a permanent solution).
Any chance this could be addressed soon?
This is becoming a serious major nightmare / time consuming issue during my working sessions.
Up. Please don’t forget this horrible bug.
Let QWERTY users work as correct as the others.
Up?
It’s a nightmare!!
Each time (3 per minute) I wanna recall the Zoom command, Rhino executes the “What” one. Etc.
I’m tired of all those unwanted commands :cry:
This is a very SERIOUS bug that have a major impact on people, like me, not working on qwerty keyboards.
I see on YT that no one is taking care of this bug.
Can something be done, please?
It’s seriously a nightmare.
Up?
It’s a nightmare!!
Yoo-hoo McNeel?? HELLO???
RH-78406 is fixed in Rhino 8 Service Release 5 Release Candidate
