Bug: Properties Panel Not Updated
I cannot understate how much of a PITA this bug is. I click on an object, change the properties, only to discover later that I have changed the properties on a different object because the properties panel has not updated.
Do you have a file that you could send me that I can test with?
I’d also be curious to know which set of tools you’ve used etc that might be triggering this.
Do newer service releases of Rhino or older versions for that matter have this same problem for you?
It happens to me with ANY file. It’s think this started with v7. I have Rhino updated to the latest version. It looks like the properties panel updates through message passing and the messages are being blocked after running Rhino for a while.
