Bug: Pdf, View Capture, Render - larger Format
hi Jeff, thanks for checking in
i have a late 2013MBP with →
regarding file, it is practically impossible to print with any file, using any random template here now small objects mm with the following settings (so mainly larger formats dont print a4 does work still)
here the file Untitled.3dm (4.3 MB)
it is set to print as raster (print as vector seems to work) but export as pdf vector or raster neither work.
also ViewCaptureToFile does produce this but also rendering it, and by the way it also does not output the requested jpg it seems stuck on png.
also here a topic from a different user in which i have collected reports from different users.
