Thursday, February 29, 2024 4:37 PM
I may have found a UI/UX bug that is difficult to explain. Control points are not visible when I toggle “F10”. When a curve is selected and the settings are set to show highlight control points, they are still not visible. the same occurs when using the push/pull command. I cannot see any dynamic extension lines for objects that I am trying to adjust.
Using “Shaded” mode as an example, all of my settings have been reset to default. I have set the control point size to 8 just to test whether or not the size changes just to be able to view it
and it does not.
Any help is greatly appreciated!
