I reported this bug some time ago, but I can’t find the topic now. However, I repeat the bug report again, because it’s still present in the latest BETA.
I also attach a sample 3dm file here (V9) to try it by yourself. You will notice that the highlight is misleading, because it gives a priority to the top and bottom surfaces when you try to snap to the center of the sideways surfaces.
Along with that, when I want to snap to the middle of the sideways edges, they will not be marked by the thicker highlight.
The bug occurs when I want to snap with “Cen” to the vertical surfaces (the thick highlight is improperly set to the top or bottom surface border), or with “Near” or “Mid” to the vertical edges (there is no thick highlight at all).
Also, it’s impossible to snap with “Cen” to the vertical surfaces when I place the mouse pointer close to their sides, i.e. the vertical edges. I’m allowed to do so only if I place the mouse pointer close to the top or bottom edges.
In my opinion, people rarely need Extrusions, yet they are set as the default geometry type for the primitives. This alone confuses many Rhino users, because the Extrusions come with some big disadvantages when it comes to using various tools, snapping and modifying their shape afterwards.
I use a stock Rhino 9 BETA to be able to find more bugs that could be fixed easily. When I use my custom settings, I find a lot more bugs. I already reported many of these in the last few months. But then Rhino WIP/BETA becomes unusable, so I switched to the stock version recently.
Even when I use regular NURBS primitives instead of Extrusions, Rhino remains a bit confused where to snap with a higher priority. I see no reason for the “Cen” snap to try to snap to the non-visible bottom surface of the box in this video when my intention is to snap to the nearest visible vertical surface.
