Bug (Maybe?): Mirroring curves with points on
Not sure if this is related to my Rhino settings but when I mirror curves with points on, even if I manually click on 0,0 coordinates the “Start of mirror plane” will always be a point on the curve
Edit: Accidental post
Edit: Rhino Version: 6.17.19235
Hello - when you select the curve, are you getting the curve itself selected or some or all of the control points?
Hi Pascal,
I make a selection of everything, including the points and curves.
Edit: I have my a bunch of curves and then turning their points on for further changes. I then select everything and mirror everything
