Bug?: Linear dimensions above line will set unit numbers away
if the dimensions space is two narrow for the font size it sets the numbers away from the dimension. A simple minimal nudge of the corresponding control point to the left will change position to normal again. It’s set above line, do I miss something.
Set the font size smaller with no effect.
Thanks
In the dimension properties, you can force “fit text” to inside instead of the default auto
Ah thanks it is working now, set a certain text gap.
