Version 8 (8.15.24352.13002, 2024-12-17)
really in a pre-chrismas rush - so sorry for not providing super precise report:
Do a Page-Layout and use multiple details, all with perspective, parallel projection.
Use complex geometry consisting of blocks.
set the display to arctic or monochrome
a lot of issues arise:
- move the detail is super slow
- print does not show the same result as in modelling view or as in screen preview
- there are artefacts if print especially with higher resolution
- Rhino Pdf - check the resulted pdf in Illustrator or Affinity-Designer / Affinity Publisher, there numerous useless, empty layers / containers (from the block definitions ?)
- unexpected shadows at the boarder of the details
- no groundplane, overlapping curves, …
- duplicating a viewport takes several seconds (nearly feels like rhino crashes, I already got panic ;-D
- duplicating a viewport does not duplicate geometry on hidden layers
Sorry if I am not motivated to dig together a public repeatable 3dm file … will upload the file in question to support later.
kind regards - tom
