Hi!
I have a display-Problem on a mac mini (Macmini 6,2 / OSX 10.13.6): the wireframe-mode does not work as expected, also in the shaded mode, when surface edges are displayed. From a simple cube only some outlines are shown, on a more complex model black triangles appear between the lines (as seen in the screenshots).
This problem does not appear on my mac pro with the same software configuration…
Rhino 5 displays the same files without issues on both macs.
Hi, Sorry for the delay in getting back to you. Are you still having these display issues? If so, can you provide the 3dm and also check if restoring these display modes to defaults makes a difference. This can be done in Rhino’s preferences (CMD + ,) > Display > then select the mode’s name to use the gear icon at the bottom of the preferences.
Thanks for your reply - one of the last WIP-updates did fix the problem. Now these display modes work as expected.
But in the meantime I realized another issue with the display mode „raytracing“: objects always render similar to arctic mode in shaded white. It is not possible to display any material color. This occurs on my mac pro and my mac mini, so I assume, this feature is not implemented yet?
Hi Martin - just to make completely sure, you are applying materials to the objects or layers and still these render white in Raytraced? What do they look like in the Rendered display mode?
