I am using the latest WIP.
I assigned text alignment and height of the text and after saved the file.
After opening all text objects are not aligned anymore and height is default (1.000 m)
Font of the text, however, is kept.
I need an urgent update of WIP with fixing of this one.
In a quick test here, I was unable to reproduce this. Could you post a file with e.g. the situation before you modify alignment, and the necessary steps in enough detail to test it?
If all goes well when compiling, a new WIP will be available Tuesday-Wednesday next week.
Hi Dmitry - I do not see this so far here- if you can post an example file with some indication of what size and alignment is expected, so I can compare, that might help.
