Bug: keyboard shortcuts fail in text inputs
This is a weird one:
When the cursor focus is in any text input area – like, the text of a text object, but also in the command line or the notes panel – typical system commands like cmd+A for “select all” or cmd+V for “paste” don’t work – they’re treated as commands.
For example, trying to create a text object with a pasted address (say 123 main st) I select the text object, click in the text field, then try to do cmd+V and rhino says “unrecognized command: 123.”
Or let’s say I’m copying and editing a text object – copy the object, then go to change the text by clicking in the text field and doing cmd+A – all objects in the viewport are selected, rather than the text itself.
I’m using Rhino 8 SR6 2024-3-14, systeminfo attached.
systeminfo.txt (4.8 KB)
minor update: the error doesn’t show up if I double-click on the text object, only in the sidebar panel(s).
