The rebuild dialog box doesn’t except enter and/or spacebar as “ok.” Have to click the ok-button.
Systeminfo_MacBook Pro.txt (5.1 KB)
Hi @Philip ,
I am unable to reproduce this one. The spacebar will not work though in the Rebuild dialog since it would add a space to any active field in the Rebuild dialog. The Enter/Return key is accepting the changes and closes the dialog here. The Rebuild button itself also closes dialog and accepts the changes. Are you still seeing this problem?
I still can - enter doesn’t work. I also think that both spacebar and enter should work as “ok” - like it usually does in Rhino. I personally don’t see a need for point count to be highlighted. If I like to change the point count I just use the arrows - or left click and entering a number.
SystemInfo MacBook Pro.txt (5.1 KB)
