#bug in bridge(weld and joint ) in subd
when i select weld and joint the object become hidden and delete in bridge command subd
and also …
the{ joint }command cannot work for sub D
and also …
Have you checked your precision when trying to join these surfaces?
There’s most certainly a gap there somewhere.
yes i cheke and test this command by several precision and several case(surface ,box …subd)
and this command cannot work
bridge subd bug.3dm (168.2 KB)
Thanks for the report, this is filed already as RH-54197 which is an internal report currently. We’ll get this tuned up soon in the WIP.
ok
thanks for reply:
