SubD joining surfaces of this handle
Hi!
how can I fill the hole between these two subD surfaces?
I’ve tried bridge command but it distorts the original shape.
Then I switched to Toggle view and tried SingleSubDface command, it doesn’t work anyway.
Any idea?
:slight_smile:
cup.3dm (3.0 MB)
Hi Erica - Bridge should work - you will need to insert a couple of edge across the handle to make the number of edges to bridge match up - but it should work fine here-
