Bug: exporting nested block doesn't add instance reference
Simple problem: when inside a block with one or more nested blocks, exporting one of the nested blocks using the file -> export selected command does not work as expected. The resulting file only has the block definition, but not the block instance inside. Opening the new file and copy+pasting the nested block works fine.
Testfile: nestedBlockExportProblem.3dm (37.2 KB)
Try to export the “ExportMe” block and see for yourself. r6 sr24 on win10.
Hello - I see that, I do not know if that is by design or not - I will dig around.
Hi RGR,
We can duplicate it.
We have logged RH-57697 Export Selected Not Working Correctly from BlockEdit
Thanks for the awesome description and models for testing.
It was very helpful for us to see the issue.
We will let you know when it is fixed so that you can test it on your system.
Kind regards,
Mary Ann Fugier
McNeel Technical Support and Training
Seattle, WA
RH-57697 is fixed in the latest Service Release Candidate
