Bug: DimAngle Offsets Text after Exploding
Hi @encephalon,
Can you provide a .3dm file for us to evaluate?
Thanks,
– Dale
hi @dale thanks for checking
i created one from scratch, just a random DimAngle, i also noticed something similar happening with normal Dimensions later on but i can not replicate that on a new file for now, in contrast to the DimAngle which seems to be happening every time.
here you go the file for DimAngle
Explode Dim Bug.3dm (75.4 KB)
just an extra notion, i installed the Wip just yesterday, i do not often explode Dimensions but i can not recall this happening before.
I see that, thanks.
RH-72429 Explode: DimAngle offsets the text
I experienced the same problem with DimOrdinate. I checked then a set of dimensioning commands and found that also DimRadius an Dimameter are affected.
Can somebody please update also the bug on YouTrack?
YouTrack: Text in Angular Dim Explodes in Incorrect Place
It would be great to have all dimens behaving well with the explode command in Rhino 9.
Regards,
Samuel
Before After Exploding.3dm (95.3 KB)
Hi Samuel -
Thanks. I’ve updated RH-72424 Text in Angular Dim Explodes in Incorrect Place
