Bug - "Delete Object" on exiting block edit
Hi McNeel
I sometimes get this error on exiting “block edit” with “ok”.
After clicking “OK” the dialog box reappears. I have to hold down escape for a while to get out of this state.
After this, the block appeared as it was before I started the edit.
Version : (8.5.24072.13001, 2024-03-12)
Rhino on windows.
Can you post a file that we can repeat this with? Thanks
Hi Japhy.
I have shared the file in a private message.
Hi @Japhy
I managed to reproduce this.
The steps are:
  1. Edit block.
  2. Attach model.
  3. Exit block edit.
I also think there are cases but maybe this could be a way to understand the issue.
Am i understanding correctly that you are attaching a worksession inside the edit block command?
I’m able to repeat this, in Rhino 7 as well.
Is this a workflow you are trying to do (attach a worksession inside a block)?
Hi @Japhy
Thank you for getting back to me.
Yes, that is correct.
I recognise that it is a strange scenario and it’s not something that I tipplely do. However, I feel like I experienced this bug relatively often. So I don’t think that is only related to this scenario. This was just the case where I was able to track down the reason for the bug.
My thinking was that if you were able to produce the error maybe it would be possible to track down other scenarios where this could happen.
-johan
Hello Mcneel
I Just experienced this bug as well. By accident i attached a worksession while editing a block. When I then tried to save my file (while inside of the block) i became stuck in the “delete object” dialog box. Losing what i had updated in the block while trying to fix the problem.
Have likewise experienced this today.
I believe it’s happened because I’m tabbing between an existing and proposed plan in different files, and updated the worksession reference whilst in a block edit, similar to the above.
Although, I’m sure I must have done this before now and not had the error.
Hi -
Thanks. I’ve filed this issue as RH-87875 BlockEdit: Delete Object Message Box
Same persistent issue here, can not dismiss the window either so having an infinite loop error
Hi Esa -
Yes, I’m afraid that issue is still waiting to be resolved.
Just to make sure…
When I tested that workflow, clicking the OK button 7 times made that message go away. From the original poster of this thread, holding down the Esc for a while also got him out of that state.
Is that not the case on your end?
Hi Wim, no effect on clicking ok nor esc, for a couple of minutes - I managed to solve the gridlock and exit the block edit mode by making a copy of the file with a new name and restarting. My original file kept on opening with the jammed block edit mode activated.
RH-87875 is fixed in Rhino BETA
