Problem with editing my Object
Hey, it is been the first time when I was using the Block command. Now I cant get out of the BlockEdit. I can only edit my stairs.
Pls help
Hi Niko,
Somewhere there you should have a Block Edit dialog box. When you’ve finished editing your block just click on the OK button.
(If you want to discard your changes click on the Close button in the dialog title instead of OK).
HTH
Jeremy
