BUG: Custom shortcuts not updated in drop down menu
I have custom keyboard shortcut for CTRL+ P, CTRL+I and many others…
simply they should not be linked anymore with Print and insert command in this dropdown menu and others
It is not an important thing but it gets confusing when I teach Rhino to beginner students
Perhaps it would be to the beginner student’s advantage if you were to teach using the default Rhino settings, saving the showcasing of your personal efficiency-enhancing modifications for a later period of their studies when it won’t be confusing and they are in a much better position to judge whether the modifications would suit them.
Yes, you are right, I realized custom keyboard and aliases are not to be introduced to beginner students.
However, if someone edit shortcuts, I still believe this bug report has a valid point
You’re right, but I bet it’s not an easy fix!
Hi Matteo -
I’ve added this thread to RH-14413 Change the shortcut
